Enables assigning an MPLS packet to a QoS profile based on the MPLS packet‘s EXP value.
Disabled.
This command enables assigning an MPLS packet to a QoS profile based on the MPLS packet's EXP value. The EXP values to QoS profile mappings are configured using the configure mpls exp examination command.
When disabled, all received MPLS packets are assigned to QoS profile qp1.
The following command enables assignment of an MPLS packet to a QoS profile based on the MPLS packet‘s EXP value:
enable mpls exp examination
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
